Introdução
You will need the proper size Phillips head screw driver to remove the screws securing the heat sink. You will also need to remove the CPU fan before you start to remove the heat sink.
O que você precisa
There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
You will need a Phillips 00 size screwdriver to remove the screws.
Prepare to remove the heatsink by removing the four screws that connect it to the motherboard.
Make sure you have a Philips 00 size screwdriver to remove the screws.
Uma outra pessoa concluiu este guia.
