Ir para o conteúdo principal
HP Envy m6-k022dx CPU Fan Replacement
O que você precisa
  1. HP Envy m6-k022dx CPU Fan Replacement, Lower Case: passo 1, imagem 1 %32
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CPU Fan Replacement: passo 2, imagem 1 %32
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CPU Fan Replacement: passo 3, imagem 1 %32
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CPU Fan Replacement: passo 4, imagem 1 %32
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CPU Fan Replacement, CPU Fan: passo 5, imagem 1 %32
    • The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
    • You will need a Phillips 00 size screwdriver to remove the screws.
  6. HP Envy m6-k022dx CPU Fan Replacement: passo 6, imagem 1 %32
    • Use your screwdriver to remove the three screws connecting the fan to the motherboard.
  7. HP Envy m6-k022dx CPU Fan Replacement: passo 7, imagem 1 %32
    • Grab the fan with your hand, and lift up and away from the motherboard.
  8. HP Envy m6-k022dx CPU Fan Replacement: passo 8, imagem 1 %32
    • Grab the fan power connector by the wires and pull directly away from port until the cable is disconnected.
Conclusão
Uma outra pessoa concluiu este guia.
Jibreel Campbell
Membro desde: 03/02/17
276 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S13-G6, Cagle Spring 2017 Membro de USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 799
