Ir para o conteúdo principal
HP Envy m6-k022dx CMOS Battery Replacement
O que você precisa
  1. HP Envy m6-k022dx CMOS Battery Replacement, Lower Case: passo 1, imagem 1 %32
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CMOS Battery Replacement: passo 2, imagem 1 %32
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CMOS Battery Replacement: passo 3, imagem 1 %32
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CMOS Battery Replacement: passo 4, imagem 1 %32
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CMOS Battery Replacement, CMOS Battery: passo 5, imagem 1 %32
    • There is a power cord connecting the CMOS battery to the motherboard. Disconnect this cord by gently pulling it up, towards the edge of the device.
  6. HP Envy m6-k022dx CMOS Battery Replacement: passo 6, imagem 1 %32
    • Once the connecting cord has been disconnected, gently lift the battery directly up, above the device.
    • The CMOS battery is now completely removed, and ready to be replaced.
Conclusão
3 outras pessoas executaram este guia.
Kareem Rigaud
Membro desde: 03/02/17
403 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S13-G6, Cagle Spring 2017 Membro de USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 2,819
