Ir para o conteúdo principal
HP Envy dv7t-7200 Service Cover Replacement
O que você precisa
  1. HP Envy dv7t-7200 Service Cover Replacement, Battery: passo 1, imagem 1 %32
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Service Cover Replacement: passo 2, imagem 1 %32 HP Envy dv7t-7200 Service Cover Replacement: passo 2, imagem 2 %32 HP Envy dv7t-7200 Service Cover Replacement: passo 2, imagem 3 %32
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Service Cover Replacement: passo 3, imagem 1 %32
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Service Cover Replacement, Service Cover: passo 4, imagem 1 %32
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Service Cover Replacement: passo 5, imagem 1 %32 HP Envy dv7t-7200 Service Cover Replacement: passo 5, imagem 2 %32
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Krystal
Membro desde: 10/16/17
882 Reputação
Autoria de 8 guias
Equipe
UW Tacoma, Team S3-G3, Liner Fall 2017 Membro de UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Membros
Autoria de 8 guias
Um comentário
I broke my computer. And I think it needs a new housing but I don’t know how much it costs
Elisha meyer Luwagga - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 382
