Ir para o conteúdo principal
HP Envy dv6-7363cl Wi-fi Card Replacement
O que você precisa
  1. HP Envy dv6-7363cl Wi-fi Card Replacement, Battery: passo 1, imagem 1 %32
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Wi-fi Card Replacement: passo 2, imagem 1 %32
    • Push the lever underneath the battery to the left as shown in the picture.
  3. HP Envy dv6-7363cl Wi-fi Card Replacement: passo 3, imagem 1 %32 HP Envy dv6-7363cl Wi-fi Card Replacement: passo 3, imagem 2 %32
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Wi-fi Card Replacement, Wi-Fi Card: passo 4, imagem 1 %32
    • After removing the battery, remove the circled screw.
  5. HP Envy dv6-7363cl Wi-fi Card Replacement: passo 5, imagem 1 %32
    • Remove the back cover.
  6. HP Envy dv6-7363cl Wi-fi Card Replacement: passo 6, imagem 1 %32
    • With the back cover removed, locate the Wi-Fi card which is positioned next to the Beats logo.
  7. HP Envy dv6-7363cl Wi-fi Card Replacement: passo 7, imagem 1 %32 HP Envy dv6-7363cl Wi-fi Card Replacement: passo 7, imagem 2 %32
    • Carefully remove gold-headed, black wires from Wi-Fi card with tweezers.
  8. HP Envy dv6-7363cl Wi-fi Card Replacement: passo 8, imagem 1 %32 HP Envy dv6-7363cl Wi-fi Card Replacement: passo 8, imagem 2 %32
    • After removing wires, remove circled screws from card.
    • Note: Laptop shown only has one screw holding in Wi-Fi card. Some models may have both.
  9. HP Envy dv6-7363cl Wi-fi Card Replacement: passo 9, imagem 1 %32 HP Envy dv6-7363cl Wi-fi Card Replacement: passo 9, imagem 2 %32
    • Wi-Fi card will raise out of device when screw is removed.
    • Gently pull card to the right to remove from device.
Conclusão
Uma outra pessoa concluiu este guia.
dylananthony
Membro desde: 10/20/16
564 Reputação
3 Guias de autoria
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 295
