Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the device upside-down so that its bottom is facing up.
Flip the laptop back over and carefully pry the keyboard frame out of the device.
Lift the keyboard out of the device
Carefully remove ribbon cables.
Flip device onto its back
Remove disk tray and circled screw.
Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
Disconnect red cord from DVD drive and remove DVD drive.
Disconnect red and white cords from blue circuit board.
Turn device onto its back and remove circled screws from Wi-Fi card.
Flip device back over and unscrew disk reader
Remove circled screws from blue circuit board and lift fan assembly out of device.
Uma outra pessoa concluiu este guia.
2 comentários
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
