Ir para o conteúdo principal
HP Envy dv6-7363cl Fan Replacement
O que você precisa
  1. HP Envy dv6-7363cl Fan Replacement, Battery: passo 1, imagem 1 %32
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Fan Replacement: passo 2, imagem 1 %32
    • Push the lever underneath the battery to the left as shown in the picture.
  3. HP Envy dv6-7363cl Fan Replacement: passo 3, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 3, imagem 2 %32
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Fan Replacement, Fan: passo 4, imagem 1 %32
    • Remove the circled screws from the back panel.
  5. HP Envy dv6-7363cl Fan Replacement: passo 5, imagem 1 %32
    • Lift and remove the back panel of the device.
  6. HP Envy dv6-7363cl Fan Replacement: passo 6, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 6, imagem 2 %32 HP Envy dv6-7363cl Fan Replacement: passo 6, imagem 3 %32
    • Flip the laptop back over and carefully pry the keyboard frame out of the device.
  7. HP Envy dv6-7363cl Fan Replacement: passo 7, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 7, imagem 2 %32 HP Envy dv6-7363cl Fan Replacement: passo 7, imagem 3 %32
    • Lift the keyboard out of the device and carefully remove ribbon cables.
  8. HP Envy dv6-7363cl Fan Replacement: passo 8, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 8, imagem 2 %32 HP Envy dv6-7363cl Fan Replacement: passo 8, imagem 3 %32
    • Flip device onto its back, remove disk tray and circled screw.
  9. HP Envy dv6-7363cl Fan Replacement: passo 9, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 9, imagem 2 %32
    • Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
  10. HP Envy dv6-7363cl Fan Replacement: passo 10, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 10, imagem 2 %32 HP Envy dv6-7363cl Fan Replacement: passo 10, imagem 3 %32
    • Disconnect red cord from DVD drive and remove DVD drive.
  11. HP Envy dv6-7363cl Fan Replacement: passo 11, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 11, imagem 2 %32 HP Envy dv6-7363cl Fan Replacement: passo 11, imagem 3 %32
    • Remove circled screws.
  12. HP Envy dv6-7363cl Fan Replacement: passo 12, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 12, imagem 2 %32
    • Disconnect red and white cords from blue circuit board.
  13. HP Envy dv6-7363cl Fan Replacement: passo 13, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 13, imagem 2 %32 HP Envy dv6-7363cl Fan Replacement: passo 13, imagem 3 %32
    • Gently pull circled pieces from their holsters.
  14. HP Envy dv6-7363cl Fan Replacement: passo 14, imagem 1 %32 HP Envy dv6-7363cl Fan Replacement: passo 14, imagem 2 %32
    • Turn device onto its back and remove circled screws from Wi-Fi card. Flip device back over and unscrew disk reader (circled in green).
  15. HP Envy dv6-7363cl Fan Replacement: passo 15, imagem 1 %32
    • Remove circled screws from blue circuit board and lift fan assembly out of device.
Conclusão
Uma outra pessoa concluiu este guia.
dylananthony
Membro desde: 10/20/16
564 Reputação
3 Guias de autoria
Equipe
2 comentários
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
zabadoo - Responder
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
Shamsullo Quzratov - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 62
Duração total: 3,935
