Ir para o conteúdo principal
HP Envy X2-15-C001Dx Hard Drive Replacement
O que você precisa
  1. HP Envy X2-15-C001Dx Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 2, imagem 1 %32 HP Envy X2-15-C001Dx Hard Drive Replacement: passo 2, imagem 2 %32
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 3, imagem 1 %32 HP Envy X2-15-C001Dx Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Envy X2-15-C001Dx Hard Drive Replacement: passo 5, imagem 2 %32
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 6, imagem 1 %32
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 8, imagem 1 %32 HP Envy X2-15-C001Dx Hard Drive Replacement: passo 8, imagem 2 %32
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 9, imagem 1 %32 HP Envy X2-15-C001Dx Hard Drive Replacement: passo 9, imagem 2 %32
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Hard Drive Replacement: passo 10, imagem 1 %32 HP Envy X2-15-C001Dx Hard Drive Replacement: passo 10, imagem 2 %32
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Hard Drive Replacement, Hard Drive: passo 11, imagem 1 %32 HP Envy X2-15-C001Dx Hard Drive Replacement, Hard Drive: passo 11, imagem 2 %32 HP Envy X2-15-C001Dx Hard Drive Replacement, Hard Drive: passo 11, imagem 3 %32
    • Lift the hard drive out from its slot, taking care not to tear the ribbon cable that is connecting it to the motherboard.
    • Unplug the hard drive from the motherboard.
    • Completely remove the hard drive from the laptop.
Conclusão
Dylan Hathaway
Membro desde: 10/25/21
686 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 2-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 597
