Ir para o conteúdo principal
HP Envy Ultrabook 4-1043cl Hard Drive Replacement
O que você precisa
  1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 2, imagem 1 %32 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 3, imagem 1 %32
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 4, imagem 1 %32 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 4, imagem 2 %32
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 5, imagem 1 %32 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 5, imagem 2 %32
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32 HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: passo 6, imagem 2 %32 HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: passo 6, imagem 3 %32
    • The hard drive is in the bottom right corner of the device which is packed by a silver metal shell.
    • Use a Phillips #00 screwdriver to remove the four 4.0 mm screws securing the hard drive to the top cover.
  7. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 7, imagem 1 %32 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 7, imagem 2 %32
  8. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 8, imagem 1 %32 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 8, imagem 2 %32
    • Pull the hard disk drive out of the connector socket and remove it from the device.
Linha de Chegada
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 697
