Introdução
If you are having issues with your hard disk drive, this guide explains how to remove the drive from the device for troubleshooting purposes or to insert a replacement hard drive.
O que você precisa
Make sure that the device is turned off and that all external devices are removed.
Using a size 0 Phillips head screwdriver, remove the four 3 mm size 0 screws attaching the hard drive casing to the device.
Quase terminado!
Conclusão
