Ir para o conteúdo principal
HP Envy Ultrabook 4-1015dx Battery Replacement
O que você precisa
  1. HP Envy Ultrabook 4-1015dx Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the device is turned off and that all external devices are removed.
  2. HP Envy Ultrabook 4-1015dx Battery Replacement: passo 2, imagem 1 %32
    • Flip the device over so that the back plate is facing upwards.
  3. HP Envy Ultrabook 4-1015dx Battery Replacement: passo 3, imagem 1 %32 HP Envy Ultrabook 4-1015dx Battery Replacement: passo 3, imagem 2 %32
    • Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
    • Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
  4. HP Envy Ultrabook 4-1015dx Battery Replacement: passo 4, imagem 1 %32 HP Envy Ultrabook 4-1015dx Battery Replacement: passo 4, imagem 2 %32
    • Using the plastic opening tool, gently pry off the back plate from the device.
  5. HP Envy Ultrabook 4-1015dx Battery Replacement: passo 5, imagem 1 %32 HP Envy Ultrabook 4-1015dx Battery Replacement: passo 5, imagem 2 %32
    • The large black box with the white warning images is the battery.
    • Move the ribbon cable so that it is no longer on top of the battery.
  6. HP Envy Ultrabook 4-1015dx Battery Replacement: passo 6, imagem 1 %32 HP Envy Ultrabook 4-1015dx Battery Replacement: passo 6, imagem 2 %32
    • Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
    • Make sure not to lose these internal screws; they will later be used to reattach the battery.
  7. HP Envy Ultrabook 4-1015dx Battery Replacement: passo 7, imagem 1 %32 HP Envy Ultrabook 4-1015dx Battery Replacement: passo 7, imagem 2 %32
    • Lift up the battery and remove it from the slot as shown.
  8. HP Envy Ultrabook 4-1015dx Battery Replacement: passo 8, imagem 1 %32 HP Envy Ultrabook 4-1015dx Battery Replacement: passo 8, imagem 2 %32 HP Envy Ultrabook 4-1015dx Battery Replacement: passo 8, imagem 3 %32
    • Use the plastic opening tool to disconnect the battery cable.
  9. HP Envy Ultrabook 4-1015dx Battery Replacement: passo 9, imagem 1 %32
    • Lift up the battery and remove it from the device.
Conclusão
Salvador Balkus
Membro desde: 10/15/18
596 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S1-G3, Valliere Fall 2018 Membro de UMass Dartmouth, Team S1-G3, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G3
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 580
