Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This is a repair guide for the speaker part of the HP Envy Touchsmart m6-k125dx.
Peças
Nenhum componente especificado.
  1. Turn the laptop over so that the bottom is facing up Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
    • Turn the laptop over so that the bottom is facing up
    • Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
  2. Carefully remove the back panel to reveal the inner components.
    • Carefully remove the back panel to reveal the inner components.
  3. First, using a Phillips Head screwdriver, unscrew the two Phillips PM 2.5x5.5 screws that are connecting the speaker to the rest of the laptop.
    • First, using a Phillips Head screwdriver, unscrew the two Phillips PM 2.5x5.5 screws that are connecting the speaker to the rest of the laptop.
  4. After unscrewing the screws, remove the speaker and carefully unplug it from the laptop. After unscrewing the screws, remove the speaker and carefully unplug it from the laptop.
    • After unscrewing the screws, remove the speaker and carefully unplug it from the laptop.
Conclusão
3 outras pessoas concluíram este guia.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 261
