Ir para o conteúdo principal
HP Envy Touchsmart m6-k125dx Hard Drive Replacement
O que você precisa
  1. HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Back Panel: passo 1, imagem 2 %32
    • Turn the laptop over so that the bottom is facing up
    • Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
  2. HP Envy Touchsmart m6-k125dx Hard Drive Replacement: passo 2, imagem 1 %32
    • Carefully remove the back panel to reveal the inner components.
  3. HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 HP Envy Touchsmart m6-k125dx Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Using the JIS screwdriver along with the J000 head, unscrew the four Phillips PM2.5x5.5 screws, and place them aside.
  4. HP Envy Touchsmart m6-k125dx Hard Drive Replacement: passo 4, imagem 1 %32
    • Carefully detach the Hard Drive Adapter, and remove the Hard Drive from the laptop.
    • Make sure not to pull from the cord; pull from the head of the adapter.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,132
