Introdução
You may need to replace the wireless adapter if your computer can't connect to any wireless network. Be sure that you do not break the antenna connector wires.
O que você precisa
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
4 outras pessoas executaram este guia.
Um comentário
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
”https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
