Ir para o conteúdo principal
HP Envy TouchSmart 15 CMOS Battery Replacement
O que você precisa
  1. HP Envy TouchSmart 15 CMOS Battery Replacement, Battery: passo 1, imagem 1 %32
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 CMOS Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 CMOS Battery Replacement, Accessory Plate: passo 3, imagem 1 %32 HP Envy TouchSmart 15 CMOS Battery Replacement, Accessory Plate: passo 3, imagem 2 %32
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 CMOS Battery Replacement: passo 4, imagem 1 %32 HP Envy TouchSmart 15 CMOS Battery Replacement: passo 4, imagem 2 %32 HP Envy TouchSmart 15 CMOS Battery Replacement: passo 4, imagem 3 %32
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: passo 5, imagem 1 %32 HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: passo 5, imagem 2 %32 HP Envy TouchSmart 15 CMOS Battery Replacement, CMOS Battery: passo 5, imagem 3 %32
    • Remove the screw from the wireless adapter with a PH0 screwdriver then move the adapter out of the way to access the CMOS battery.
  6. HP Envy TouchSmart 15 CMOS Battery Replacement: passo 6, imagem 1 %32
    • Use a plastic or metal spudger to release the CMOS battery from the clips.
  7. HP Envy TouchSmart 15 CMOS Battery Replacement: passo 7, imagem 1 %32 HP Envy TouchSmart 15 CMOS Battery Replacement: passo 7, imagem 2 %32
    • Remove the battery from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Robert Patterson
Membro desde: 09/04/15
1.457 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 2-6, Sullivan Fall 2015 Membro de USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 18
Ao todo: 7,833
