Introdução
This guide will help you in replacing the touchpad on your HP Envy Sleekbook m6-k010dx. Make sure to turn the device off before doing anything.
Peças
Não são necessárias peças.
  1. Remove the four 9mm Phillips #00 screws.
    • Remove the four 9mm Phillips #00 screws.
    • Remove the eight 9mm Phillips #00 screws.
  2. Use the plastic opening tool and your hands to remove the bottom cover.
    • Use the plastic opening tool and your hands to remove the bottom cover.
    • Disconnect the battery power cable from the motherboard.
    • Remove the six 6mm Phillips #00 screws from the battery.
    • Lift the battery out of the laptop.
    • Lift the white tab on the ZIF connector to unlock the ribbon cable.
    • Pull the ribbon cable out of the ZIF connector.
    • Remove the seven 3mm Phillips #00 screws from the trackpad.
    • Use the plastic opening tool to lift the touchpad up and pull out to remove.
Conclusão
codi whittaker
433 reputação
3 Guides authored
Equipe
USF Tampa, Team S1-G4, Nance Spring 2018 Membro de USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Todo: 100
