Ir para o conteúdo principal
HP Envy Sleekbook m6-k010dx LCD Replacement
O que você precisa
  1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: passo 1, imagem 1 %32
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 2, imagem 1 %32 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 3, imagem 1 %32
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 4, imagem 1 %32
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 5, imagem 1 %32 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 5, imagem 2 %32
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: passo 6, imagem 1 %32 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: passo 6, imagem 2 %32
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 7, imagem 1 %32
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 8, imagem 1 %32 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 8, imagem 2 %32 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 8, imagem 3 %32
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 9, imagem 1 %32 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 9, imagem 2 %32
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 10, imagem 1 %32 HP Envy Sleekbook m6-k010dx LCD Replacement: passo 10, imagem 2 %32
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. HP Envy Sleekbook m6-k010dx LCD Replacement: passo 11, imagem 1 %32
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
Conclusão
codi whittaker
Membro desde: 02/14/18
508 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G4, Nance Spring 2018 Membro de USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 24
Ao todo: 985
