Introdução
If your computer turns on but nothing is displayed on the LCD, it might be time to replace it. This guide will walk you through each step.
Peças
Não são necessárias peças.
  1. Remove the four 9mm Phillips #00 screws.
    • Remove the four 9mm Phillips #00 screws.
    • Remove the eight 9mm Phillips #00 screws.
  2. Use the plastic opening tool and your hands to remove the bottom cover. Use the plastic opening tool and your hands to remove the bottom cover.
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. Disconnect the battery power cable from the motherboard. Remove the six 6mm Phillips #00 screws from the battery.
    • Disconnect the battery power cable from the motherboard.
    • Remove the six 6mm Phillips #00 screws from the battery.
  4. Lift the battery out of the laptop. Lift the battery out of the laptop.
    • Lift the battery out of the laptop.
  5. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Remove the stickers from the bottom left and right corner of the device with a plastic opening tool. Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. Use the plastic opening tool to pry the bezel free from the LCD housing. Use the plastic opening tool to pry the bezel free from the LCD housing. Use the plastic opening tool to pry the bezel free from the LCD housing.
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen. Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. Use the plastic opening tool to remove the LCD screen from its housing. Lay the LCD screen flat on the keyboard.
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. Disconnect the cable which connects the LCD to the motherboard.
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
Conclusão
codi whittaker
433 reputação
3 Guides authored
Equipe
USF Tampa, Team S1-G4, Nance Spring 2018 Membro de USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Todo: 127
