Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use the plastic opening tool and your hands to remove the bottom cover.
Disconnect the battery power cable from the motherboard.
Remove the six 6 mm Phillips #00 screws from the battery.
5 outras pessoas executaram este guia.
Um comentário
I am going to give this a try.. I took it to Best Buy Geek Squad, they had it for over 3 weeks and said they couldn’t find the part cause my laptop is to old. This wasn’t the only issue. The touchpad wasn’t working and I troubleshooted the problem and I fixed it myself.
I will add another comment once i replace the battery
