Ir para o conteúdo principal
HP Envy Sleekbook m6-k010dx Battery Replacement
O que você precisa
  1. HP Envy Sleekbook m6-k010dx Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx Battery Replacement: passo 2, imagem 1 %32 HP Envy Sleekbook m6-k010dx Battery Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx Battery Replacement: passo 3, imagem 1 %32
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx Battery Replacement: passo 4, imagem 1 %32
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx Battery Replacement: passo 5, imagem 1 %32 HP Envy Sleekbook m6-k010dx Battery Replacement: passo 5, imagem 2 %32
    • Lift the battery out of the laptop.
Conclusão
5 outras pessoas executaram este guia.
Ana Novo
Membro desde: 02/14/18
410 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G4, Nance Spring 2018 Membro de USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
Membros da 4
Autoria de 15 guias
Um comentário
I am going to give this a try.. I took it to Best Buy Geek Squad, they had it for over 3 weeks and said they couldn’t find the part cause my laptop is to old. This wasn’t the only issue. The touchpad wasn’t working and I troubleshooted the problem and I fixed it myself.
I will add another comment once i replace the battery
momw4boys - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 31
Duração total: 9,005
