Introdução
We will be showing you how to properly take apart your computer without causing damage. Replacing the touch pad is not as simple as one may thing. You will have to buy a full new face plate because the touch pad is built in.
O que você precisa
Using a Phillips #1, remove the 8 10.6mm screws.
Also using a Phillips #1, remove the 8.6mm screw.
3 outras pessoas executaram este guia.
Um comentário
I recently replaced my front face plate on my Envy M6, which originally had one in a natural silver finish. I can confirm that the onyx black one works equally well. To think it was a Lithuanian part too. I completed the guide, but mistakenly forgot to reconnect the touchpad ribbon. But that’s my fault.
