Ir para o conteúdo principal
HP Envy M6-1205DX Palm Rest Replacement
O que você precisa
  1. HP Envy M6-1205DX Palm Rest Replacement, Battery: passo 1, imagem 1 %32
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Palm Rest Replacement: passo 2, imagem 1 %32
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Palm Rest Replacement: passo 3, imagem 1 %32 HP Envy M6-1205DX Palm Rest Replacement: passo 3, imagem 2 %32
    • Remove the battery.
  4. HP Envy M6-1205DX Palm Rest Replacement, Back Panel: passo 4, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the 8.6 mm screw.
  5. HP Envy M6-1205DX Palm Rest Replacement: passo 5, imagem 1 %32
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Palm Rest Replacement, Palm Rest: passo 6, imagem 1 %32
    • Set the computer facing upwards again.
    • Using the plastic opening tool gently pry the keyboard up.
  7. HP Envy M6-1205DX Palm Rest Replacement: passo 7, imagem 1 %32 HP Envy M6-1205DX Palm Rest Replacement: passo 7, imagem 2 %32 HP Envy M6-1205DX Palm Rest Replacement: passo 7, imagem 3 %32
    • Flip the white tab on the large ribbon cable upward. Gently pull the large ribbon cable out to remove it.
    • Gently pull the small ribbon cable out to remove it.
  8. HP Envy M6-1205DX Palm Rest Replacement: passo 8, imagem 1 %32 HP Envy M6-1205DX Palm Rest Replacement: passo 8, imagem 2 %32 HP Envy M6-1205DX Palm Rest Replacement: passo 8, imagem 3 %32
    • Gently pull the tension cable to remove it.
  9. HP Envy M6-1205DX Palm Rest Replacement: passo 9, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the four 5.6 mm silver screws.
  10. HP Envy M6-1205DX Palm Rest Replacement: passo 10, imagem 1 %32 HP Envy M6-1205DX Palm Rest Replacement: passo 10, imagem 2 %32
    • Use the plastic opening tool to loosen the palm rest from the frame.
    • Once you pry all of the snaps up lift off the palm rest.
Conclusão
Ryan Hatton
Membro desde: 11/16/19
634 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S2-G2, Wilson Fall 2019 Membro de IUPUI, Team S2-G2, Wilson Fall 2019
IUPUI-WILSON-F19S2G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 293
