Ir para o conteúdo principal
HP Envy M6-1205DX Motherboard Replacement
O que você precisa
  1. HP Envy M6-1205DX Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Motherboard Replacement: passo 2, imagem 1 %32
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Motherboard Replacement: passo 3, imagem 1 %32 HP Envy M6-1205DX Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the battery.
  4. HP Envy M6-1205DX Motherboard Replacement, Touchpad: passo 4, imagem 1 %32
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Motherboard Replacement: passo 5, imagem 1 %32
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Motherboard Replacement: passo 6, imagem 1 %32
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Motherboard Replacement: passo 7, imagem 1 %32
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Motherboard Replacement: passo 8, imagem 1 %32 HP Envy M6-1205DX Motherboard Replacement: passo 8, imagem 2 %32
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Motherboard Replacement: passo 9, imagem 1 %32 HP Envy M6-1205DX Motherboard Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Motherboard Replacement: passo 10, imagem 1 %32 HP Envy M6-1205DX Motherboard Replacement: passo 10, imagem 2 %32
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Motherboard Replacement: passo 11, imagem 1 %32 HP Envy M6-1205DX Motherboard Replacement: passo 11, imagem 2 %32 HP Envy M6-1205DX Motherboard Replacement: passo 11, imagem 3 %32
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Motherboard Replacement: passo 12, imagem 1 %32 HP Envy M6-1205DX Motherboard Replacement: passo 12, imagem 2 %32 HP Envy M6-1205DX Motherboard Replacement: passo 12, imagem 3 %32
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Motherboard Replacement: passo 13, imagem 1 %32
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Motherboard Replacement: passo 14, imagem 1 %32 HP Envy M6-1205DX Motherboard Replacement: passo 14, imagem 2 %32
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
  15. HP Envy M6-1205DX Motherboard Replacement, Fan: passo 15, imagem 1 %32
    • Using a Phillips #1, remove the two 10.6 mm screws.
    • Gently pull back on on the cable to unplug it.
  16. HP Envy M6-1205DX Motherboard Replacement: passo 16, imagem 1 %32
    • Pull the fan out to remove it.
  17. HP Envy M6-1205DX Motherboard Replacement, Motherboard: passo 17, imagem 1 %32 HP Envy M6-1205DX Motherboard Replacement, Motherboard: passo 17, imagem 2 %32
    • Using a Philips #1, remove the five 5.0 mm screws.
    • Gently pull the mini power connectors to remove them.
    • Gently pull the two ribbon cables to remove them.
    • Pull the black tab to remove the LCD screen connector.
  18. HP Envy M6-1205DX Motherboard Replacement: passo 18, imagem 1 %32
    • Gently pull the motherboard away from the case on the lower left-hand corner.
  19. HP Envy M6-1205DX Motherboard Replacement: passo 19, imagem 1 %32
    • Gently pull the case away from the motherboard on the upper right-hand corner.
  20. HP Envy M6-1205DX Motherboard Replacement: passo 20, imagem 1 %32
    • Pull the motherboard out of the laptop, taking care to detach the cable on the underside as you do so.
Conclusão
3 outras pessoas executaram este guia.
Ryan Hatton
Membro desde: 11/16/19
634 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S2-G2, Wilson Fall 2019 Membro de IUPUI, Team S2-G2, Wilson Fall 2019
IUPUI-WILSON-F19S2G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 951
