Ir para o conteúdo principal
HP Envy 700-030qe Solid State Drive Replacement
O que você precisa
  1. HP Envy 700-030qe Solid State Drive Replacement, Solid State Drive: passo 1, imagem 1 %32
    • Before beginning, it is good to wear an anti-static wrist band to prevent electrical components from getting harmed.
    • Attach the anti-static wristband to your wrist, and clip the other end to an exposed piece of metal anywhere on the case.
  2. HP Envy 700-030qe Solid State Drive Replacement: passo 2, imagem 1 %32
    • Start by opening the device case by unscrewing the 10.5mm hand screw on the back of the computer.
    • If the hand screw is too tight, you may use the Torx T15 screwdriver to remove it.
  3. HP Envy 700-030qe Solid State Drive Replacement: passo 3, imagem 1 %32
    • Turn the computer onto its side to continue removing the case cover.
    • Slide the cover off by sliding it to the right.
  4. HP Envy 700-030qe Solid State Drive Replacement: passo 4, imagem 1 %32 HP Envy 700-030qe Solid State Drive Replacement: passo 4, imagem 2 %32
    • Locate the SSD inside the open case.
    • Unplug the SATA power cable from the hard drive by pulling straight up.
  5. HP Envy 700-030qe Solid State Drive Replacement: passo 5, imagem 1 %32
    • Finish disconnecting the hard drive by unplugging the black SATA interface cable by pulling up.
  6. HP Envy 700-030qe Solid State Drive Replacement: passo 6, imagem 1 %32
    • To remove the SSD and its casing, pull out on the side silver tab.
    • At the same time, pull up on the hard drive. It should slide out smoothly without much effort.
  7. HP Envy 700-030qe Solid State Drive Replacement: passo 7, imagem 1 %32
    • To completly remove the SSD from its casing, unscrew the four 5mm screws on opposite ends of the casing. Use a Torx T15 screw driver to accomplish this.
    • Notice that the screws to remove are the four screws inside the holes rather than the screws that are next to the holes.
  8. HP Envy 700-030qe Solid State Drive Replacement: passo 8, imagem 1 %32
    • Finally, slide the SSD out of the casing.
Conclusão
4 outras pessoas executaram este guia.
Chandler Warne
Membro desde: 10/01/15
273 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-9, Maness Fall 2015 Membro de Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 2,565
