Ir para o conteúdo principal
HP Envy 700-030qe Power Supply Replacement
O que você precisa
  1. HP Envy 700-030qe Power Supply Replacement, Power Supply: passo 1, imagem 1 %32 HP Envy 700-030qe Power Supply Replacement, Power Supply: passo 1, imagem 2 %32 HP Envy 700-030qe Power Supply Replacement, Power Supply: passo 1, imagem 3 %32
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe Power Supply Replacement: passo 2, imagem 1 %32 HP Envy 700-030qe Power Supply Replacement: passo 2, imagem 2 %32
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe Power Supply Replacement: passo 3, imagem 1 %32
    • Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
  4. HP Envy 700-030qe Power Supply Replacement: passo 4, imagem 1 %32 HP Envy 700-030qe Power Supply Replacement: passo 4, imagem 2 %32
    • Undo the clasp which holds the power supply in place by pushing down on it.
    • Pull out the power supply up and towards you.
  5. HP Envy 700-030qe Power Supply Replacement: passo 5, imagem 1 %32
    • Unplug the power cable going to the CD drive by pulling straight.
  6. HP Envy 700-030qe Power Supply Replacement: passo 6, imagem 1 %32
    • Set aside the power supply on the left side of the computer.
  7. HP Envy 700-030qe Power Supply Replacement: passo 7, imagem 1 %32
    • Unplug the SATA interface power cable going to the hard drive by pulling straight up.
  8. HP Envy 700-030qe Power Supply Replacement: passo 8, imagem 1 %32
    • Unplug the power cable going to the mother board by pulling straight up.
  9. HP Envy 700-030qe Power Supply Replacement: passo 9, imagem 1 %32
    • Unplug the power cable going to the fan by pulling straight up.
Conclusão
Yoav Rosenberg
Membro desde: 10/01/15
321 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 5-9, Maness Fall 2015 Membro de Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 48
Duração total: 4,263
