Ir para o conteúdo principal
HP Envy 700-030qe CPU Fan Replacement
O que você precisa
  1. HP Envy 700-030qe CPU Fan Replacement, CPU Fan: passo 1, imagem 1 %32 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: passo 1, imagem 2 %32 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: passo 1, imagem 3 %32
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe CPU Fan Replacement: passo 2, imagem 1 %32 HP Envy 700-030qe CPU Fan Replacement: passo 2, imagem 2 %32
    • Next, remove the side panel by sliding it towards the back of the desktop and pulling up, as shown.
  3. HP Envy 700-030qe CPU Fan Replacement: passo 3, imagem 1 %32
    • Remove the four 120mm Phillips #000 head, 5 mm screws holding the fan.
  4. HP Envy 700-030qe CPU Fan Replacement: passo 4, imagem 1 %32
    • Carefully pull up and disconnect the fan's power cable.
  5. HP Envy 700-030qe CPU Fan Replacement: passo 5, imagem 1 %32
    • Remove the fan by pulling up carefully.
Conclusão
Jessica Resta
Membro desde: 10/01/15
235 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-9, Maness Fall 2015 Membro de Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
Membros da 4
Autoria de 10 guias
4 comentários
Im looking to replace the fan in mine, what size would I look for, or even what model would be best?
AzyP Zero - Responder
Did you ever determine what fan to use ? I need to order one for my system.
Dennis - Responder
I bought the Philips #000 Screwdriver from iFixit as listed above. It is not even close to what is needed. That screwdriver is like a jewelers tiny Philips head. It needs a much bigger screwdriver.
Dennis - Responder
Fails to mention the most important part of the entire procedure. That would be to remove the old thermal paste from the top of the CPU with 91-99% isopropyl alcohol and re-apply new thermal paste. Short of doing this almost guarantees failure to maintain proper cooling.
Guy Martin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 3,344
