Ir para o conteúdo principal
HP Envy 5660 Scanner Piece Replacement
O que você precisa
  1. HP Envy 5660 Scanner Piece Replacement, Scanner Glass: passo 1, imagem 1 %32
    • Open the cartridge access area.
  2. HP Envy 5660 Scanner Piece Replacement: passo 2, imagem 1 %32
    • Remove the three 11.5 mm screws with a T10 bit.
  3. HP Envy 5660 Scanner Piece Replacement: passo 3, imagem 1 %32 HP Envy 5660 Scanner Piece Replacement: passo 3, imagem 2 %32 HP Envy 5660 Scanner Piece Replacement: passo 3, imagem 3 %32
    • Locate the cover hinge on the right side of the printer.
    • Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
  4. HP Envy 5660 Scanner Piece Replacement: passo 4, imagem 1 %32 HP Envy 5660 Scanner Piece Replacement: passo 4, imagem 2 %32
    • Remove the 12 mm screws on the left side of the printer with a T10 bit.
  5. HP Envy 5660 Scanner Piece Replacement: passo 5, imagem 1 %32 HP Envy 5660 Scanner Piece Replacement: passo 5, imagem 2 %32
    • Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
    • Since this is a compression spring, the hinge will snap downwards as soon as it is loosened.
  6. HP Envy 5660 Scanner Piece Replacement: passo 6, imagem 1 %32 HP Envy 5660 Scanner Piece Replacement: passo 6, imagem 2 %32 HP Envy 5660 Scanner Piece Replacement: passo 6, imagem 3 %32
    • Pull the plastic side cover off of the printer.
    • You may need to lift the printer and push the cover downwards as it is latched onto the bottom of the printer.
    • Plastic opening tools or a metal spudger may also be used.
  7. HP Envy 5660 Scanner Piece Replacement: passo 7, imagem 1 %32
    • Remove the five 11.5 mm screws located at the bottom of the scanner.
    • Steps 3-6 were intended to create easier access to these screws. However, they will still be difficult to reach.
    • The top of the scanner will now easily pull off.
  8. HP Envy 5660 Scanner Piece Replacement: passo 8, imagem 1 %32 HP Envy 5660 Scanner Piece Replacement: passo 8, imagem 2 %32
    • Pry the old scanning glass up with a metal spudger.
    • There are adhesives under the scanning glass. Be careful not to break the glass while removing it.
  9. HP Envy 5660 Scanner Piece Replacement, Scanner Piece: passo 9, imagem 1 %32 HP Envy 5660 Scanner Piece Replacement, Scanner Piece: passo 9, imagem 2 %32 HP Envy 5660 Scanner Piece Replacement, Scanner Piece: passo 9, imagem 3 %32
    • The scanning piece is located in the bottom half of the scanner that was not separated from the printer.
    • Lift the scanning piece and detach the ribbon cable by gently pulling on it.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Steakley
Membro desde: 01/23/18
781 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G6, Livingston Winter 2018 Membro de Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 895
