Ir para o conteúdo principal
HP Envy 4520 Lid Backing Replacement
  1. HP Envy 4520 Lid Backing Replacement, Lid Backing: passo 1, imagem 1 %32
    • Grab hold of the front and back of the left side of the lid backing.
    • Face the printer towards you and push the lip of the lid back towards the lid hinges.
    • You may need to apply a lot of pressure to the lid. You will hear two clicks when the hinge releases.
  2. HP Envy 4520 Lid Backing Replacement: passo 2, imagem 1 %32 HP Envy 4520 Lid Backing Replacement: passo 2, imagem 2 %32
    • Lay the lid with the white backing facing up with the lip of the lid facing your body.
    • Peel the white backing away gently.
    • There will be a layer of foam glued to the bottom of the white lid backing.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 792
