Introdução
The AC adapter may need to be replaced if you are experiencing issues with the power connection to your printer. The removable power cord is plugged into the AC adapter.
O que você precisa
Ensure that the printer is turned off.
Locate and remove the black power cord from the back of the printer.
3 outras pessoas executaram este guia.
2 comentários
Forgot a step at the beginning. Have to remove the inside clip connected to the lid. If you only remove the outside clip in step 2 and not the inside clip, it will snap. This clip triggers the cartridges to slide to the left when the lid is open for replacement.
