Ir para o conteúdo principal
HP Envy 4-1105dx Battery Replacement
O que você precisa
  1. HP Envy 4-1105dx Battery Replacement, Battery: passo 1, imagem 1 %32
    • Power off the device before beginning disassembly. Disconnect all external devices.
    • Flip the device on its back.
  2. HP Envy 4-1105dx Battery Replacement: passo 2, imagem 1 %32
    • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
  3. HP Envy 4-1105dx Battery Replacement: passo 3, imagem 1 %32
    • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
  4. HP Envy 4-1105dx Battery Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
  5. HP Envy 4-1105dx Battery Replacement: passo 5, imagem 1 %32
    • Once the device is open, move the ribbon cable to the side.
  6. HP Envy 4-1105dx Battery Replacement: passo 6, imagem 1 %32
    • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
  7. HP Envy 4-1105dx Battery Replacement: passo 7, imagem 1 %32
    • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
  8. HP Envy 4-1105dx Battery Replacement: passo 8, imagem 1 %32
    • Lift the battery up and remove.
    • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Worked very well, many thanks
Tony Chan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 1,205
