Introdução
Use this guide to replace your hard drive. If you have determined that your hard drive is not working or if you want a hard drive with more storage space, it may be time to replace it.
O que você precisa
Remove the four 4.0 mm screws that hold down the hard drive case using a Philips #1 Screwdriver.
Move the hard drive case and hard drive so that you can easily reach the hard drive cable.
3 outras pessoas executaram este guia.
