Ir para o conteúdo principal
HP Envy 4-1030us Wireless Card Replacement
O que você precisa
  1. HP Envy 4-1030us Wireless Card Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Envy 4-1030us Wireless Card Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Wireless Card Replacement: passo 2, imagem 1 %32 HP Envy 4-1030us Wireless Card Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Wireless Card Replacement, Wireless Card: passo 3, imagem 1 %32 HP Envy 4-1030us Wireless Card Replacement, Wireless Card: passo 3, imagem 2 %32
    • After removing the bottom cover, the wireless card is accessible toward the rear of the system.
    • The wireless card may be underneath a piece or layer of black protective electrical tape. Carefully peel back the tape to access the card.
  4. HP Envy 4-1030us Wireless Card Replacement: passo 4, imagem 1 %32 HP Envy 4-1030us Wireless Card Replacement: passo 4, imagem 2 %32
    • Disconnect the wires from the wireless card by lifting them up from the metal studs they are set on.
    • The wires are not screwed onto the studs, but may still require some wiggling or twisting to help them come off.
  5. HP Envy 4-1030us Wireless Card Replacement: passo 5, imagem 1 %32
    • Using the Phillips #0 screwdriver unscrew the single 2.5mm screw holding the card to the motherboard.
  6. HP Envy 4-1030us Wireless Card Replacement: passo 6, imagem 1 %32
    • Slide the card out of it's connector.
    • After removing the screw, the card will lift at an angle in its connector.
Conclusão
Uma outra pessoa concluiu este guia.
Christopher Luna
Membro desde: 10/08/17
700 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G1, Thompson Fall 2017 Membro de USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 225
