Ir para o conteúdo principal
HP Envy 4-1030us Hard Drive Replacement
O que você precisa
  1. HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Hard Drive Replacement: passo 2, imagem 1 %32 HP Envy 4-1030us Hard Drive Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • After removing the cover the mSATA SSD should be visible near the center of the device.
    • Remove the one Phillips 2.5mm screw holding the SSD in place. The drive should pop up after removing the screw.
  4. HP Envy 4-1030us Hard Drive Replacement: passo 4, imagem 1 %32
    • To remove the SSD grab the edges and pull it from the slot.
    • Try not to touch any pins or connectors. Damaged pins could result in permanent damage to the system.
Conclusão
Christopher Luna
Membro desde: 10/08/17
700 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G1, Thompson Fall 2017 Membro de USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 845
