Ir para o conteúdo principal
HP Envy 4-1030us CPU Fan Replacement
O que você precisa
  1. HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us CPU Fan Replacement: passo 2, imagem 1 %32 HP Envy 4-1030us CPU Fan Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us CPU Fan Replacement, CPU Fan: passo 3, imagem 1 %32
    • Using the Phillips #0 screwdriver unscrew the two 4.2mm screws fastening the CPU fan to the heatsink and motherboard.
  4. HP Envy 4-1030us CPU Fan Replacement: passo 4, imagem 1 %32 HP Envy 4-1030us CPU Fan Replacement: passo 4, imagem 2 %32
    • Carefully lift up the CPU fan to gain better access to the fan cable.
    • Disconnect the fan cable by pulling the cable away from the connector and remove the fan from the device.
Conclusão
Christopher Luna
Membro desde: 10/08/17
700 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G1, Thompson Fall 2017 Membro de USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 383
