Ir para o conteúdo principal
HP Envy 23-d060qd TouchSmart RAM Replacement
O que você precisa
  1. HP Envy 23-d060qd TouchSmart RAM Replacement, Back Panel: passo 1, imagem 1 %32
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart RAM Replacement: passo 2, imagem 1 %32
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart RAM Replacement: passo 3, imagem 1 %32
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: passo 4, imagem 1 %32 HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: passo 4, imagem 2 %32
    • Pop off the easy-access cover to get into the RAM module.
  5. HP Envy 23-d060qd TouchSmart RAM Replacement: passo 5, imagem 1 %32 HP Envy 23-d060qd TouchSmart RAM Replacement: passo 5, imagem 2 %32
    • Push out the four clips that hold the RAM modules to the side.
    • The RAM modules will pop open after you unclick all four clips.
  6. HP Envy 23-d060qd TouchSmart RAM Replacement: passo 6, imagem 1 %32
    • Pull out each module.
    • Replace RAM with desired replacement.
    • When substituting your RAM in, make sure to line up the edges with the lines on the RAM compartment so that the RAM is able to fit inside properly.
Conclusão
4 outras pessoas executaram este guia.
Zachary Dicks
Membro desde: 10/01/15
1.117 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 5-10, Maness Fall 2015 Membro de Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 3,203
