Ir para o conteúdo principal
Introdução
As I was moving my computer into another room I dropped it and the screen cracked. What steps can I take to keep from having to continue to use a broken screen? I know replacing a screen is a very lengthy and delicate procedure.
  1. Use your hands to unclip the plastic snaps on the back panel of the device.
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. Remove the three 11.5mm PH2 screws from the back panel.
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. Now, take the back panel off by pulling at it gently with your hands.
    • Now, take the back panel off by pulling at it gently with your hands.
  4. Use your hands to unclip the plastic bezels for the DVD drive and ports. To unclip the plastic bezels, push the middle of each plastic bezel towards the center of the computer, and then pull them outwards.
    • Use your hands to unclip the plastic bezels for the DVD drive and ports.
    • To unclip the plastic bezels, push the middle of each plastic bezel towards the center of the computer, and then pull them outwards.
    • You may want to lay the computer face down, on a flat, clean surface to ensure nothing falls out when disassembling the computer for next steps.
    One screw to remove the DVD drive is easier and safer than removing the bezel.
    Art Venable - Responder
    Hi where can i find the Display?
    Erkan Tekin - Responder
  5. Remove the nineteen 10mm T15 black screws from the edge of the computer.
    • Remove the nineteen 10mm T15 black screws from the edge of the computer.
    • Lay the computer on its front when preforming this step, and leave it face down for the rest of the guide.
    Had to remove the base assembly to get at one of the screws holding the display on.
    Had to disconnect speaker wires.
    Also had to disconnect a number of small connections at the top of the device - webcam, microphone, etc.
  6. Lift up the computer by the base very slowly, and disconnect the three wired connections to the display with your hands. Always disconnect wired connections from the plastic base.
    • Lift up the computer by the base very slowly, and disconnect the three wired connections to the display with your hands. Always disconnect wired connections from the plastic base.
  7. Set the computer aside, and use a small knife to cut the strips attaching the display to the digitizer.
    • Set the computer aside, and use a small knife to cut the strips attaching the display to the digitizer.
  8. Use a plastic spudger to unclip the 3 ribbon clips on the back of the display.
    • Use a plastic spudger to unclip the 3 ribbon clips on the back of the display.
  9. Remove the four 7mm T15 silver screws from the edge of the computer.
    • Remove the four 7mm T15 silver screws from the edge of the computer.
  10. Gently pull the display free from the digitizer with your hands.
    • Gently pull the display free from the digitizer with your hands.
  11. Remove the four 17.5mm T15 screws from the speakers. When the speakers are free, use your hands to pull them free from the digitizer.
    • Remove the four 17.5mm T15 screws from the speakers.
    • When the speakers are free, use your hands to pull them free from the digitizer.
  12. Remove the three 10mm T15 screws from bezel.
    • Remove the three 10mm T15 screws from bezel.
  13. Use your hands to pull the plastic bezel off of the digitizer.
    • Use your hands to pull the plastic bezel off of the digitizer.
Conclusão
7 outras pessoas concluíram este guia.
Zachary Dicks
Membro desde: 01/10/2015
1.056 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team 5-10, Maness Fall 2015 Membro de Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Membros
14 Guias de autoria
On step 5 you've to remove also the 4 silver screw that keep display to the mainboard chassis.
illola - Responder
From where can I buy the glass to replace?
Aram Vardanyan - Responder
i wont 5 pics please send yor number watsap or send me Offer price for HP ENVY 23-d117a glass
Thanks >>
Feras emad
00966543470171
info@fersawy.com
Feras Emad - Responder
687535-001 this is the part required
Model No HP envy 23 Delhi 0201 N.
Serial no. CZC 31443 LD kindly let me know whether it is available and please mail the details to sunitha.jijo@yahoo.com
Sunitha.jijo@yahoo.com - Responder
Hi.
My touchscreen has been cracked too.
Can anyone help to direct me to somewhere to buy a replacement screen please?
frank_scullion@yahoo.co.uk
Thanks in anticipation
Frank Scullion - Responder
I need replacement digitizer. pls contact if you have any thx. mavioglu@hotmail.com
oguz - Responder
Hi,
My touchscreen has been broken and i need a new one for replacement or if some technical support do it.
hp envy recline 23-k220ne
My email is:
alberto@surweb.es
thanks ;)
Alberto - Responder
Hi, I also need a new screen for my hp envy 23 , links would be greatly appreciated
glg2401@gmail.com
George - Responder
i need a 23 inch hp touchsmart screen very badly anyone???
jayfinks - Responder
Hi, I am in need of the replacement glass for my HP ENVY 23 touchscreen also. It fell and cracked while in transportation. The computer is still operational but my glass screen is cracked in a about 8 places. Where can I find the glass cover for this touchscreen at a reasonable price? Reach me at : ( markmccord71801@att.net ). Thanks for the assistance.
Mark McCord - December 5th, 2018
markmccord71801 - Responder
Depends on what you think is reasonable. There are several on eBay, but there are variations in the ribbon cable configurations within the same series, which means you probably will have to disassemble to see which one you need.
Amy Stinson -
Im also looking for a screen for my HP Envy Touchsmart 23se-d494 anyone know where to buy one??
Derek Vasquez - Responder
glass replacement the computer still works?
Need to replace a glass for HP Envy 23-d160qd.
Availability ? Cost ?
Scott 'Dragon' Runde - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 105
Duração total: 11,325
