Ir para o conteúdo principal
HP Envy 17m-ae111dx CPU Fan Replacement
O que você precisa
  1. HP Envy 17m-ae111dx CPU Fan Replacement, Back Cover: passo 1, imagem 1 %32
    • Power off your laptop before beginning disassembly.
    • Place the laptop on its back.
  2. HP Envy 17m-ae111dx CPU Fan Replacement: passo 2, imagem 1 %32 HP Envy 17m-ae111dx CPU Fan Replacement: passo 2, imagem 2 %32 HP Envy 17m-ae111dx CPU Fan Replacement: passo 2, imagem 3 %32
    • Remove the plastic covering to the Disk Reader.
    • Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
    • If the button on the side is jammed, pry off the covering by using the iFixit Opening Tool.
  3. HP Envy 17m-ae111dx CPU Fan Replacement: passo 3, imagem 1 %32 HP Envy 17m-ae111dx CPU Fan Replacement: passo 3, imagem 2 %32 HP Envy 17m-ae111dx CPU Fan Replacement: passo 3, imagem 3 %32
    • Unscrew all visible screws.
    • Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
    • One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
  4. HP Envy 17m-ae111dx CPU Fan Replacement: passo 4, imagem 1 %32 HP Envy 17m-ae111dx CPU Fan Replacement: passo 4, imagem 2 %32
    • Pry the gripper completely off to expose the two screws.
    • Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
  5. HP Envy 17m-ae111dx CPU Fan Replacement: passo 5, imagem 1 %32 HP Envy 17m-ae111dx CPU Fan Replacement: passo 5, imagem 2 %32 HP Envy 17m-ae111dx CPU Fan Replacement: passo 5, imagem 3 %32
    • Use the iFixit opening tool to pry off the back cover.
    • Ensure that you go all the way around the laptop with the tool to take it off.
  6. HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: passo 6, imagem 1 %32 HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: passo 6, imagem 2 %32 HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: passo 6, imagem 3 %32
    • Use the Phillips #00 screwdriver to remove the three 5.5mm screws that secure the fan.
    • Unplug the wire that is connected to the fan and move the wires so they are out of the way of the fan.
    • Remove the tape off of the fan that is holding the wires in place against the fan.
  7. HP Envy 17m-ae111dx CPU Fan Replacement: passo 7, imagem 1 %32 HP Envy 17m-ae111dx CPU Fan Replacement: passo 7, imagem 2 %32
    • Remove the fan from the laptop, ensuring the wires are properly disconnected.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
Excellent video...extremely helpful...thank you
Frank D - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 37
Duração total: 1,866
