Introdução
The WLAN module works the wifi that comes and goes from the laptop. So replacing this whenever goes faulty is important and thankfully is easy to fix! Be sure to keep yourself grounded to eliminate static!
O que você precisa
Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
Uma outra pessoa concluiu este guia.
