Introdução
The CPU plays the most important part to the laptop's system as it is where everything is done. The most important part is also the most easy to be broken so a lot of care must be taken in order to fix this! Keep yourself grounded and do not bend the pins!
O que você precisa
Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
Locate the 7mm screw for the optical drive right next to the WLAN and Memory modules.
Remove the screw with a PH1-screwdriver to release the CD-drive.
Uma outra pessoa concluiu este guia.
