Introdução
Use this guide if you want to replace the motherboard of your HP Envy 17-J013CL. The motherboard is the guts of the computer where all the internal parts connect together to make the whole thing work. Without it there is no way for signals and information to pass along one another. There are a lot of pins, sockets, and ports so it is important to stay grounded and be gentle with it. Bending it can also break it!
O que você precisa
Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
Locate the 7mm screw for the optical drive right next to the WLAN and Memory modules.
Remove the screw with a PH1-screwdriver to release the CD-drive.
4 outras pessoas executaram este guia.
Um comentário
What is the proper name of the housing that the motherboard sets in? I need to order one of these because all the hinge plastic is broken.
TIA
Jim
