Introdução
The subwoofer gives this laptop a much deeper sound compared to other ones. This guide will show you how to replace it, should the original fail in your HP Envy 17-3070NR.
O que você precisa
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
Remove the subwoofer by pulling straight up from the main assembly.
