Ir para o conteúdo principal
HP Envy 17-3070NR Subwoofer Replacement
O que você precisa
  1. HP Envy 17-3070NR Subwoofer Replacement, Back Cover: passo 1, imagem 1 %32 HP Envy 17-3070NR Subwoofer Replacement, Back Cover: passo 1, imagem 2 %32
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Subwoofer Replacement: passo 2, imagem 1 %32 HP Envy 17-3070NR Subwoofer Replacement: passo 2, imagem 2 %32 HP Envy 17-3070NR Subwoofer Replacement: passo 2, imagem 3 %32
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: passo 3, imagem 1 %32 HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: passo 3, imagem 2 %32 HP Envy 17-3070NR Subwoofer Replacement, Subwoofer: passo 3, imagem 3 %32
    • Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
    • Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
    • Remove the subwoofer by pulling straight up from the main assembly.
Conclusão
Abby Lentz
Membro desde: 04/21/15
586 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-8, Amido Spring 2015 Membro de Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 537
