Ir para o conteúdo principal
HP Envy 17-3070NR Optical Drive Replacement
O que você precisa
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: passo 1, imagem 1 %32 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: passo 1, imagem 2 %32
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: passo 2, imagem 1 %32 HP Envy 17-3070NR Optical Drive Replacement: passo 2, imagem 2 %32 HP Envy 17-3070NR Optical Drive Replacement: passo 2, imagem 3 %32
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: passo 3, imagem 2 %32 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: passo 3, imagem 3 %32
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: passo 5, imagem 1 %32 HP Envy 17-3070NR Optical Drive Replacement: passo 5, imagem 2 %32 HP Envy 17-3070NR Optical Drive Replacement: passo 5, imagem 3 %32
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Conclusão
Jon Fuson
Membro desde: 04/21/15
140 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-8, Amido Spring 2015 Membro de Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,224
