Introdução
Use this guide to replace the hard drive of your HP Envy 17-3070NR. Whether you want to upgrade your storage, improve performance by switching to SSD or replace a faulty HDD, this guide is for you. Note that there are two bays for the drives on this laptop. Therefore, if you want to simply add another drive consider plugging it in into second cavity using already included connector.
O que você precisa
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
Remove the hard drive by lifting it out of its cavity.
Unplug the hard drive cable that connects it to the main assembly.
Uma outra pessoa concluiu este guia.
