Ir para o conteúdo principal
HP Envy 15-u001dx Motherboard Replacement
O que você precisa
  1. HP Envy 15-u001dx Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Flip the device over so the bottom is is facing up.
    • Peel up the two rubber feet closest to the hinge using the metal spudger to reveal two 6.6 mm Phillips #0 screws.
  2. HP Envy 15-u001dx Motherboard Replacement: passo 2, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 2, imagem 2 %32
    • Peel up the small plastic coverings in the middle of the device with the spudger to reveal two more 6.6 mm Phillips #0 screws.
  3. HP Envy 15-u001dx Motherboard Replacement: passo 3, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 3, imagem 2 %32
    • Remove each of the fourteen 6.6 mm Phillips #0 screws with the Philips #0 screwdriver.
  4. HP Envy 15-u001dx Motherboard Replacement: passo 4, imagem 1 %32
    • Flip the device over and open it to reveal the keyboard.
    • Use the metal spudger to pry the chassis apart and reveal the inside of the device.
  5. HP Envy 15-u001dx Motherboard Replacement: passo 5, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 5, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 5, imagem 3 %32
    • Disconnect the T/P cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  6. HP Envy 15-u001dx Motherboard Replacement: passo 6, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 6, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 6, imagem 3 %32
    • Disconnect the keyboard cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  7. HP Envy 15-u001dx Motherboard Replacement: passo 7, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 7, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 7, imagem 3 %32
    • Disconnect the battery cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  8. HP Envy 15-u001dx Motherboard Replacement: passo 8, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 8, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 8, imagem 3 %32
    • Disconnect the AUX/USB cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  9. HP Envy 15-u001dx Motherboard Replacement: passo 9, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 9, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 9, imagem 3 %32
    • Disconnect the cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  10. HP Envy 15-u001dx Motherboard Replacement: passo 10, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 10, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 10, imagem 3 %32
  11. HP Envy 15-u001dx Motherboard Replacement: passo 11, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 11, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 11, imagem 3 %32
  12. HP Envy 15-u001dx Motherboard Replacement: passo 12, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 12, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 12, imagem 3 %32
    • Disconnect the cable by gently pulling it out. The spudger may be used to help loosen it.
  13. HP Envy 15-u001dx Motherboard Replacement: passo 13, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 13, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 13, imagem 3 %32
    • Remove the three 4.0 mm Phillips #0 screws with the Phillips #0 screwdriver on the fan.
    • Remove the fan by pulling it out of the chassis.
    • The connector tends to get stuck and forceful pulling will break it. Use the spudger to loosen the connector on each side.
  14. HP Envy 15-u001dx Motherboard Replacement: passo 14, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 14, imagem 2 %32 HP Envy 15-u001dx Motherboard Replacement: passo 14, imagem 3 %32
    • This connector may be hard to see because it is connected on the underside of the motherboard.
  15. HP Envy 15-u001dx Motherboard Replacement: passo 15, imagem 1 %32
    • Remove each of the six 4.0 mm screws with the Philips #0 screwdriver.
  16. HP Envy 15-u001dx Motherboard Replacement: passo 16, imagem 1 %32
    • Remove each of the three 4.0 mm screws around the fan with the Philips #0 screwdriver.
    • The fan will now be loose, and easy to lift out.
  17. HP Envy 15-u001dx Motherboard Replacement: passo 17, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 17, imagem 2 %32
    • Gently pry the heat sink loose to release the motherboard.
  18. HP Envy 15-u001dx Motherboard Replacement: passo 18, imagem 1 %32 HP Envy 15-u001dx Motherboard Replacement: passo 18, imagem 2 %32
    • Disconnect the wifi card from the motherboard and remove the motherboard from the rest of the device.
  19. HP Envy 15-u001dx Motherboard Replacement: passo 19, imagem 1 %32
    • The disconnected motherboard should look like the indicated photo.
Conclusão
Nathan Browning
Membro desde: 11/04/19
373 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G1, Henning Fall 2019 Membro de IUPUI, Team S1-G1, Henning Fall 2019
IUPUI-HENNING-F19S1G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 524
