Ir para o conteúdo principal
HP Envy 15-u001dx Hard Drive Replacement
O que você precisa
  1. HP Envy 15-u001dx Hard Drive Replacement, HP Envy 15-u001dx Disassembly: passo 1, imagem 1 %32
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Hard Drive Replacement: passo 4, imagem 1 %32
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Envy 15-u001dx Hard Drive Replacement: passo 5, imagem 2 %32
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Gently remove hard drive from its connector.
Conclusão
Dakota Presley
Membro desde: 10/05/16
885 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 9-4, Lacy Fall 2016 Membro de USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 48
Duração total: 1,948
