Introdução
This guide will walk you through 9 easy steps to replace your HP Envy 14 Notebook screen! Before following this guide, you should order and receive the replacement screen and find an open space to work on.
O que você precisa
With your laptop turned off and facing down, locate the battery.
Slide and hold the black tabs while removing the battery. One of the black tabs may lock in place once slided over.
Use the plastic card or your fingernail to separate the black plastic border from the screen case.
3 outras pessoas executaram este guia.
2 comentários
GIbt ein neues Modell (Spectre)... da wirds mit dem Display dank Verklebung echt sch....
Hi, do you think this would work with HP Envy 15 TouchSmart? For blank screen problem, if it is not the display, it may be the ribbon. Which one is the ribbon in your instructions above? Thanks!
