Introdução
This guide provides detailed instructions to replace your laptops speakers or check its connection to the motherboard. Before you open your laptop try to troubleshoot other problems first, our troubleshooting page may help. If you determine that the speakers themselves are the issue follow this guide to replace them.
O que você precisa
Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
Use the Phillips 0 screwdriver to remove the four 3mm Phillips screws from the speaker assembly.
Uma outra pessoa concluiu este guia.
