Ir para o conteúdo principal
HP Elitebook x360 1040 G5 Screen display Replacement
O que você precisa
  1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: passo 1, imagem 1 %32 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: passo 1, imagem 2 %32 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: passo 1, imagem 3 %32
    • Open your laptop.
    • Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
    • Continue to apply heat for 5 to 10 minutes.
  2. HP Elitebook x360 1040 G5 Screen display Replacement: passo 2, imagem 1 %32 HP Elitebook x360 1040 G5 Screen display Replacement: passo 2, imagem 2 %32 HP Elitebook x360 1040 G5 Screen display Replacement: passo 2, imagem 3 %32
    • Using the jimmy tool pry outward on the screen display, starting near one of the top corners.
    • Carefully pry along the perimeter of the display until the screen can be easily removed.
    • Lay the screen face down on the keyboard for the next step.
  3. HP Elitebook x360 1040 G5 Screen display Replacement: passo 3, imagem 1 %32 HP Elitebook x360 1040 G5 Screen display Replacement: passo 3, imagem 2 %32
    • Carefully remove the clear adhesive protector from the smallest ribbon cable, located closest to the laptop hinge.
    • Gently slide the connector out of the harness, moving it towards the side of the laptop with the power button.
  4. HP Elitebook x360 1040 G5 Screen display Replacement: passo 4, imagem 1 %32 HP Elitebook x360 1040 G5 Screen display Replacement: passo 4, imagem 2 %32 HP Elitebook x360 1040 G5 Screen display Replacement: passo 4, imagem 3 %32
    • Carefully remove the clear adhesive protector from the last ribbon cable, located on the large black strip on the back of the screen display.
    • Gently remove the ribbon cable from the harness by moving it toward the laptop hinge.
  5. HP Elitebook x360 1040 G5 Screen display Replacement: passo 5, imagem 1 %32 HP Elitebook x360 1040 G5 Screen display Replacement: passo 5, imagem 2 %32 HP Elitebook x360 1040 G5 Screen display Replacement: passo 5, imagem 3 %32
    • Remove the screen from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler A Cobb
Membro desde: 09/03/19
321 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G1, Hovde Fall 2019 Membro de IUPUI, Team S1-G1, Hovde Fall 2019
IUPUI-HOVDE-F19S1G1
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 44
Duração total: 1,514
