Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Begin by removing the computers back covering.
Use the right slider to unlock the backing.
Slide the backing towards you while holding the slider to remove it.
Once the backing is removed, locate the panel to the left where the optical drive is stored.
Locate the single screw in the photo.
Unscrew the 0.8mm Phillips screw and place to the side.
Locate the small metal piece in the photo.
Using a tool, push the piece in the given direction.
Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
Grab the optical drive and carefully remove it from the back of the computer.
